Clemi
18.11.2010, 17:01
hallo wollte mal fragen ob mir einer von euch sagen kann ob ein hardtp der serie 2 auch auf die serie 1 passt ???
Hi Chris,
grundsätzlich ja, aber es gebe verschiedene Befestigungssätze je nach Baujahr und ORGA-Nummer (aus dem Federdom vorne Fahrerseite)
---Zitat---
If you buy a second-hand hard top, you need to be sure that the fitting kit is
complete (details below) and that it is compatible with the type of windscreen
joint on your car.
For the purpose of roof fitment, 306's are divided into four types:
Phase 1 models:
- Type 1: from the first example (DAM = 6230) to the 2,000th (DAM = 6338)
- Type 2: from 25/2/1994 (DAM = 6339) to 18/4/1994 (DAM = 6378)
- Type 3: from 19/4/1994 (DAM + 6379) to the fitting of the revised
windscreen joint at facelift
Phase 2 and 3 models:
- Type 4: facelift models onwards, with revised 'v' shaped windscreen joint.
Various adaptations are needed to fit the hard top according to the date of the
car's manufacture, but it we cannot go into too much detail here. 2 kits are
available from Peugeot:
- 8446.C2 for the first three types (phase 1 cars)
- 8446.99 for the final type (phase 2 and 3 cars)
Contents of a fitting kit
Fitting kit
- 1 flat 17mm spanner to tighten the side brackets
- 2 side brackets, height adjustable, with screws
- 2 elastic straps to hold the plastic covers
- 1 large spanner to turn the nuts of the roof
- 2 quarter panel covers
---Zitat Ende---
Quelle: PCOCLUB
Gruß CptAGE
gibt es eine Teilenummer für die Plastikblenden re. und li. und für den "Spezialschlüssel"?
Sind die Teile noch lieferbar?
bnmondi
Meines Wissens nach nur im Satz erhältlich...
Gruß CptAGE
