pep508
27.01.2012, 13:38
(Achtung: Long posting - in änglischer sprache :-) )
My Peugeot 508 was delivered this week. Sleek car which I love, but the Navigation system (which I in the following call: NAV+ - Peugeot calls it WIP NAV+, Citroën calls it Emyway and internally at PSA it is known as RT6) is terrible. I have no quips regarding route planning algorithm, map or route display, but the User control functionality is awful, especially when it comes to the telephone bluetooth functionality. The documentation in the Owners Handbook is pretty bad, which is a problem when the system is not intuitive.
I have listed below my findings and the issues I see, needs to be fixed. I would appreciate anybody supplementing / correcting / commenting on these findings. My mobile is an iPhone 4, - I do not know to what extent my findings also reflect other mobile phones. Your comments to this is also appreciated. Here goes:
WIP NAV + - How does the iPhone Bluetooth connection work ??
1. When the mobile phone is bluetooth connected to the system , after a little time, NAV+ sees all contacts in the phone. ALL. They can be listed via the ADDR book, and contains names, tel. numbers, addresses. It is NOT possible to make only a part of the contacts available via iPhone contact groups.
2. When looking for a phone number, one has to scroll through all (up to 400) contacts alphabetically with the dial. No facility for jumping.
2. If Bluetooth connection is cut, the contacts disappear, i.e. they are not transferred to NAV+, only accessed in the iPhone via Bluetooth. Nevertheless, there is a max limit of 400 entries that NAV+ can accept.
3. The iPhone contacts can be listed and tel. numbers dialed via NAV+ (use *green telephone* button + *Directory*)
4. The addresses from the iPhone address book can NOT be used for navigation. A MAJOR flaw!
5. In NAV+, iPhone contacts can be deleted from the NAV+ list, but no data are ever deleted or changed in the iPhone. Next time the NAV+ system is started with Bluetooth connection to the iPhone, all iPhone contacts are again copied to volatile NAV+ memory (System says: *Synchronization successful*)
5. Via NAV+ input, new entries can be made to the address book (dial, push-for-letter, dial, push-for-letter, etc. etc.) Names, addresses, phone numbers can be added. Such entries can be used 1) navigation and 2) for dialing via NAV+
6. In the Navigation menu, addresses can be entered. Such addresses can also be given a name. These entries will appear in the *recently visited*; list from which they can be opened and saved permanently (button: *Archive*). However, names give are not saved, only the addresses. Instead, the address is copied into the name field, and cannot be changed.
Summary of functionality, that needs to be changed, for the system to become user-friendly:
A) Make it possible to access / load a subset of all addresses. Most obvious implementation would be to allow download of a particular contacts group (iPhone and Microsoft Outlook both use contact groups)
B) Make it possible to go quickly to a contact in the list. Most obvious implementation: spell via Control Dial.
C) Make it possible to navigate to the address of an iPhone contact. This is a Priority requirement!
D) Make it possible to give navigated-to addresses a name and save both in the NAV+ directory.
E) Make it possible to permanently download iPhone contacts into the NAV+ directory. Also make it possible to NOT automatically *synchronize* iPhone contacts when Bluetooth connection is established.
